Odd Switch Plate
Old 10-05-13, 01:08 PM
K
Question Odd Switch Plate
I have a 3 gang toggle switch where the toggles are closer together than normal. Most switches are about 1.5 inches apart, whereas these are about 5/8" apart. I need a new cover for it and can't figure out what it is called or where to find one.
Please advise.
Thanks!
Old 10-05-13, 01:13 PM
ray2047's Avatar
Pictures might help. http://www.doityourself.com/forum/li...-pictures.html Is this line voltage or low voltage switching?
Old 10-05-13, 01:19 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
Welcome to the forums!
We'll need some more information to go on. Is this a triplex switch or three separate switches? What is the make and model stamped on it, or them? Can you post a picture of what you have? See How To Include Pictures.
ECHO, Echo, Echo, echo, [SUB]echo[/SUB]
Old 10-07-13, 07:23 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Can you simply tap the switches apart some in the box to adjust them to fit? just a thought.
Old 10-07-13, 08:24 AM
Nashkat1's Avatar
From 5/8" to 1-1/2"? That's a 7/8" shift!
BTW, I just measured a couple to be sure and yes, it is more than 1-1/2". Two devices in a 2-gang box are 1-13/16" apart, center-to-center.
Old 10-07-13, 08:59 AM
A
Received 91 Upvotes on 83 Posts
Probably Despard - Despard Wall Plates
