Reload this Page >
Any problem using fluo lamp 120v 60Hz on 100v 50Hz electrical supply?
Old 10-08-13, 01:03 AM
D
I have 2 nice table lamps equipped with FC5 22W circular T5 fluorescent lights that I plan to bring to Japan. They are US standards 120v 60Hz and in Japan we have 100v 50Hz. I do not plan to add any kind of converter; therefore I would like to know if it would work properly. Thanks.
Old 10-08-13, 03:23 AM
H
At first I thought you might not have any problems with your light but wasn't sure. According to a wiki travel article about electrical items Fluorescent lights in particular tend to not work right if the voltages is not right. Here is a link to the article I found Electrical systems - Wikitravel . It also mentions other things besides lighting so I hope you read the whole article it should help you with other things as well. I wish you a nice stay in Japan!
Old 10-08-13, 03:57 AM
A
Received 288 Upvotes on 263 Posts
The fluorescent light ballast, if marginal, can overheat on the lower 50 Hz frequency AC and/or pass so much current actually resulting n an overvoltage that damages the lamps. Alternatively the 100 volts may be too much of a "brownout" for the 120 volt innards to operate the lamps properly.
