installing a pp20 powerpack to 227 volt switch
Received 0 Votes
I can't understand the 2 hot wires the instructions read for 227 volt circuit attach orange and blue wire to line wire from wall switch and connect other blue wire to load. which is attached to neutral and white wire from power pack to neutral. both wires from wall switch are hot with a ground wire and neutral wire. can anyone help?
Welcome to the forums.
You're messing with 277vac and you don't understand the PP-20 wiring ? Be careful.
The white and black/orange power the module and the blue wires are nothing more than a N.O. switch that closed with a remote input.
So the white goes to neutral
The black/orange and one of the blues goes to 277v.
The other blue goes to your light fixture(s).
Received 0 Votes
I have a black wire, a white wire, and a ground on the old switch that I have removed to install the sensor. How do I determine which wire is the Load and which wire is the hot? aren't both sides of a 277 light switch Hot? white and black? I have fried to install the sensor a blue and orange to the black wire, and the other blue wire to the white, but it worked for a second then stopped .
Do you even have 277 volts available? Is this in a house? If this is commercial, I would say you need to hire an electrician for liability reasons and the knowledge.
Based on your description of what you have available..... you have a switch leg. A hot wire and a switched output (hot) wire. You are missing a neutral which means you can't use the PP-20 in that location.
