Help Needed Light Switch Setup Correction
Old 10-13-13, 12:43 PM
Previous owner screwed up garage lighting. I probably wont make much sense here but I will give it a shot, check out the diagram below too. Basically (yeah right) I am Trying to control 3 lights.
Garage subpanel with 2 20 amp breakers tied together.
Box one has a single pole (miswired).
In that box there is a black (line) another black (controls 1 of the 3 lights). and 2 reds (which I think should be the travelers of a 3 way switch). One red is pigtailed with the second black and connects to single pole to make the circuit with the black (line). The other red is capped. No white/neutrals in switch box.
Box 2 has a three way.
Black (common) and 2 reds (travelers). No white neutrals in switch box.
When single pole is switched on the three way in box 2 only controls 2 of the 3 lights. When single pole is off in box one, the 3 way in box 2 has no power. The extra black in box 1 controls the 3rd light and is only controled by the single pole in box 1.
I put in a 3 way in box 1, hooked black (line) to common and the two reds to the travelers like the 3 way in box 2. They both control 2 of the 3 lights correctly. THe other black which sends power to the 3rd light is now capped but I am unsure where to to pigtail this second black wire to send power to the 3rd light (for the 3rd light).
There is another switch with basic wiring in box 1 but Im not sure how the neutrals are shared (ie 2 breakers tied together). If I tie it to the that switch and the hot going to it is on one leg of the neutral is on the other, is that unacceptable?
Below is my diagram, I guess I Will throw it out there, please ask me to clarify anything and I will post right back. Heres the link to a bigger version :
http://tiny(space)url.com/k29b79a
(you'll need to remove the "space" so it shows properly) .
Thanks, Mike.
Need some help correcting switch setup, the photo hopefully depicts on how it is miswired now:
[ATTACH=CONFIG]19217[/ATTACH]
Heres the link.
https://lh4.googleusercontent.com/-UVFWW
Old 10-13-13, 01:45 PM
Welcome to the forums.
You've got a lot going on here and quite a bit to digest.
How many switches do you have in box 1 ?
Since you have an awful lot of colors with no whites can we assume it's all in pipe ?
The only time you'd have black and white on a switch is if that was part of a switch loop.
I couldn't access your tinypic link nor the google link.
Old 10-13-13, 02:24 PM
ray2047's Avatar
Tinypic is blocked by the forum. http://www.doityourself.com/forum/li...-pictures.html
Old 10-13-13, 04:28 PM
Hi - thanks for looking. The crude diagram I have is in the body of the message or you can see a bigger version at the following link:
Please cut and past address, then remove the "(space)" to view.
Any ideas would be great... I have a specific question that I will hold off until someone can offer their input.
Old 10-13-13, 05:37 PM
Ok.....I see your diagram.
