Retrofit wire pulling
Old 10-25-13, 02:10 PM
I had to add a wire to an existing junction box by fishing it in one of the knockouts on the box in a finished ceiling.
My question is how do I get a cable connector on that wire? I have zero access to the outside of the box because it is in a finished ceiling. Is it ok to install the cable connector on the inside of the junction box?
All opinions appreciated.
Old 10-25-13, 02:18 PM
ray2047's Avatar
Use a push in plastic connector.
Old 10-25-13, 03:34 PM
Mr.Awesome's Avatar
Tie a string to the cable, pull it back out, attach the connector (remove the locknut), pull the cable back in with the string. Then just slip the locknut on and gently tighten it by tapping a flatblade against the locknut with pliers.
Old 10-28-13, 02:57 PM
Found a plastic cable connector - awesome and thanks for the heads up.
