Reload this Page >
Recessed remodel light won't work when ground is connected
Old 10-26-13, 10:37 PM
Fixture: Utilitech 3-inch Standard Remodel Recessed Light
Wiring three of these in a series in side a 6-inch high soffit I built under some high cabinetry.
Home built 1980's, standard wiring setup. This should be straight forward, I have done it a hundred times, but...
Lights 1 and 3 in the series work great. Light 2 works when hot and neutral are wired up, but shuts off when I wire up the grounds.
Fixture has a filament ground attached to the light housing, which I am wiring in with the two copper grounds from the romex.
Any ideas?
Old 10-27-13, 12:04 AM
Probably something wrong with the factory wiring on fixture number two. These things ARE made in China to sell in the US cheaply.
Old 10-27-13, 02:57 AM
ray2047's Avatar
What is a filament ground.? Only the metal structure and housing should be grounded.
Do you mean dasiy chained paralell connected?
