Cooper RF9534 and RF9542
Old 10-28-13, 01:05 PM
Hello All,
I have racked my brain for hours with these stupid switches..
I have installed the switches 1 master and the other accessory dimmer exactly like in the wiring diagram. The master works fine (I only have one pot light connected of 16 so far) I can dim it up and down and turn it off and on. However the accessory dimmer just shows an orange LED and doesn't do anything??
I switched the blue wires .. nothing...
It could be possible that I have a dud - but I have another RF9542 and it's the same result.
Any thoughts??? Thanks
Old 10-28-13, 03:46 PM
Nashkat1's Avatar
Welcome to the forums!
Interesting question. A link, or links, to the installation instructions for the specific ASPIRE controls you're working with might help us spot something.
Describe the cables and wires in each box, and tell us which of those wires you've connected to each device.
Old 10-28-13, 05:24 PM
Cooper
Thanks - good point!
Here is the PDF instruction sheet - I am using a two location setup.
http://www.cooperindustries.com/cont...2_instruct.pdf
I have attached pics at both ends. First picture is the accessory and the second is the master.
Thanks VERY much for your help.
Old 10-28-13, 06:35 PM
Nashkat1's Avatar
That's the instructions for an RF9542 accessory dimmed. We'll need one for the other device too.
Thanks, but the pictures don't show how everything is connected and don't have any information about the cables and wires. Please answer the original request:
Each cable and each wire in each box. Which is power in and which is the feed to the fan/light. Which are the travelers. And how each is connected to each device.
Old 10-29-13, 07:53 AM
Thanks
Ok - got my head out of my butt.
Here is the link
http://www.cooperindustries.com/cont...s/600cy_pt.pdf
Here are the photos worked out..
Old 10-30-13, 08:08 AM
Got it .. thanks for the reply..
As it turns out - if you don't have the minimum wattage load on the circuit it won't work.
Old 10-30-13, 03:25 PM
Nashkat1's Avatar
Glad you got it, and thanks for the feedback. That outcome makes sense but isn't necessarily intuitive. Your posting of it may help a lot of other members and readers.
