Help with DC fan hookup in house
Old 10-28-13, 01:57 PM
not related to this post but can't see how to ask a question,
I have a 12v dc bilge fan that i am trying to hook up in the house to move the hot air from living room thru a pipe to bedrooms, i have a led driver thats knocked the voltage down and the fan works but its pulsing instead of a steady airflow...
Old 10-28-13, 02:22 PM
Welcome to the forums from the UK.
I gave you your very own thread.
You more than likely need a different type of power supply. Some bilge fans are brush type motors which may not run on an LED driver supply.
Is there a specification sheet/tag on or with that fan ?
It should say 12vdc at xx amps.
Old 10-29-13, 07:19 AM
Hi thanks for the thread, nothing came with it, its an Attwood 3000 turbo. Linda x
Old 10-29-13, 08:10 AM
Based on the fan specs. you would need a power supply that is at least 3 amps to run that fan properly.
Which LED driver are you using ?
