Dimmer Switch
Received 0 Votes
Dimmer Switch
Hello, I am trying to install a dimmer switch in my dining room. When I took off the face plate I noticed that their are the wires from a wall outlet connected. Can I still install a dimmer switch and if so how? Thanks
The dimmer should connect to the wiring on the old switch. Do not make any changes to any other wiring in the switch box.
How many and what colors are connected to the switch?
Welcome to the forums!
A receptacle?
Connect the dimmer switch to the same wires the old switch was connected to. Are you replacing an on/off switch or a 3-way switch?
