Soldered Connection - old wiring
Old 11-03-13, 03:33 AM
House is almost 60 y.o. Wired with TW wire.
Sometimes when I go to swap an outlet, I find soldered connections capped with an old style nut and taped over with fabric type electrical tape.
If I am forced to re-pigtail, I have a mess between tape residue and the soldered connection and I am hesitant to seperate everything and resplice.... Im worried I may break insulation or a wire.
Should I be remaking these old connections as I go or leave them be?
Besides rewire, how should I approach this? Is this stuff to old to work with?
Old 11-03-13, 03:47 AM
pcboss's Avatar
If you already have pigtails for the devices I would leave it as is. If not you can add pigtails using a wire but. No need for tape also.
The worse problem is the insulation may be dried out, especially from heat, and crack and fall off.
