Hard wire vs plug on new disposal
Old 11-03-13, 10:52 AM
K
I am replacing a garbage disposal that is hard wired into the box with a new disposal that has a plug. Should I install a receptacle on the elec box for the plug, or remove the cord from the new disposal and hard wire like the previous one?
thanks.
Old 11-03-13, 10:55 AM
Received 4,154 Upvotes on 3,730 Posts
Welcome to the forums.
I would remove the hard wire connection and install a handibox and a receptacle for the new disposer.
Old 11-03-13, 11:06 AM
K
Thank you PJ. This is helpful.
Old 11-03-13, 11:21 AM
In thinking further on this matter and based on what I had read on another forum I had mistakenly posted that a GFI receptacle was required due to the 6' rule from the kitchen sink but based on aandpdan's post I dug further just to make sure and based on the newest code found that a GFI receptacle was not needed.
The wording of Section 210.8(A)(7)is intended to make it clear that other receptacles, such as dishwasher and disposal receptacles that may be within 6 feet of a kitchen countertop sink,
are not required to have GFCI protection.
Thanks for the heads up aandpdan.
Old 11-03-13, 06:37 PM
A
Received 5 Upvotes on 4 Posts
A GFCI is not required in the kitchen for a disposer.
Only the receptacles serving the countertop require GFCI protection. NEC 210.8(a)(6).
Old 11-03-13, 07:55 PM
CasualJoe's Avatar
Received 192 Upvotes on 172 Posts
Not yet anyway. I believe that may be coming in 2014.
