Quick Cable Location Question
Old 11-03-13, 04:26 PM
G
Fixing up some walls and a doorway. Previous homeowner ran a cable through the door frame, as you can see in the pictures.
I need to move it, and am wondering if anybody sees any problem with me running a new cable through the studs above the door frame? Specifically wondering about the studs that are angled. Can i treat them the same as other studs, with regard to passing a cable through?
Thanks. Name:  20131103_163655.jpg
Old 11-03-13, 04:36 PM
Received 4,140 Upvotes on 3,718 Posts
Yes....you can drill them the same as regular beams. Those are pretty heavy and will be a treat to drill.
Old 11-03-13, 04:40 PM
ray2047's Avatar
Just use a 3/4"-7/8" hole centered and you should be fine. The new cable will have to run all the way from the lsst box before the door to the first box after the door unless you use permanently accessible Jboxes.
Old 11-03-13, 05:09 PM
pcboss's Avatar
Received 206 Upvotes on 179 Posts
No problem drilling above the door.
