New bath exhaust fan wiring questions
Old 11-04-13, 08:27 PM
F
Everyone here was so helpful and informative with my last posts (thanks again), that I'm back for some more help.
I purchased a NuTone basic exhaust fan and have a couple of questions about wiring it.
I have an empty 15 amp breaker in my panel and attached to it is a coil of 100' of 14/2 romex, the end of which is in a junction box in the basement (the breaker is taped in the off postion). This was left for future needs.
I was wondering if:
(1) this breaker and gauge of wire are suitable for installing the NuTone 696FN exhaust fan. It will be dedicated only for this purpose.
(2) do I wire from the panel to the switch then to the fan? or...
(3) ...from the panel to the fan and then to the switch?
Thanks in advance for any help. I'm sure I'll be back with more questions, along with some diagrams to help me visualize your responses.
Fran
Old 11-04-13, 08:34 PM
ray2047's Avatar
Yes, that would be fine.
That is the best because you are now required to have a neutral in the switch box.
I'd suggest you run 14-3 from switch to light as future proofing should you ever want a fan with light.
Old 11-04-13, 08:37 PM
Received 4,153 Upvotes on 3,730 Posts
You could certainly use that circuit to power the fan with plenty of left over capacity. That fan only draws 1amp.
The junction boxes on those fans is on the small side. It would be easier to run the feed to the switch and then another line from the switch to the fan.
(stereo responses)
Old 11-04-13, 10:05 PM
F
What type of switch do I use?
Old 11-04-13, 10:46 PM
ray2047's Avatar
Just a regular "light" switch or you could use a timer..
Old 11-04-13, 11:22 PM
F
I'm a little confused, I always work better with pictures.
So, I have the black, white and ground wires comming from the panel. They go to the switch.
The black, white and ground wires from the switch connect to the black, white and ground wires of the fan motor.
I guess what I'm missing is how the wires are connected at the switch???
...help? diagrams??
Fran
Old 11-05-13, 12:07 AM
B
Switch for fan
Hot (120V)--------------Switch-------------------------fan motor
White (GCC)-------------------------------------------- fan motor
Bare (ground)---------switch---------------------------fan motor
The 15amp single-pole switch goes in series with the Hot (120V) from your breaker and then to the fan motor. The grounded circuit conductor (white) splices through the switch box and goes to the fan motor. The ground goes from the panel to the switch ground terminal and splices through the switch box and goes to the fan motor ground terminal.
Old 11-05-13, 05:39 AM
ray2047's Avatar
Here is a rough diagram. Grounds not shown. If metal box grounds connected together and pigtailed to box. Optional but recommended also pigtailed to switch. If box plastic grounds connected together and must be pigtailed to switch.
Old 11-05-13, 03:13 PM
F
Thank you Ray and bahtah. I think i understand now. Is my attached pic correct?
Old 11-05-13, 03:22 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
Yes. I would install a timer rather than an on/off switch.
Old 11-05-13, 03:53 PM
F
Would the wiring of a timer differ from the single-pole switch wiring?
Old 11-05-13, 03:57 PM
ray2047's Avatar
If it has a neutral then the neutral wire will go to the neutral. Other then that it will be the same.
Old 11-05-13, 06:47 PM
F
Thank you everyone for your quick input and assistance. Once again, it was a pleasure comming to this site for guidance.
Cheers,
Fran
