Amperage drop/wire size
Old 11-05-13, 01:07 PM
Need to figure amperage drop/wire size, on buried cable for 70 amps over 200 ft. Using aluminum. HELP!!
Old 11-05-13, 01:47 PM
Nashkat1's Avatar
Welcome to the forums!
Amperage doesn't drop with distance. Voltage does. The conservative value is to limit the voltage drop to 3% or less. The calculation for the wire size needed to do that is based on distance, load and wiring method. The information we need is:
  • Is the distance from breaker to load exactly 200 ft?
  • What is the maximum load? So you need a foll 70A?
  • Are you planning to pull individual aluminum conductors in buried conduit, or some other method?
  • Is single-phase 240V correct?
