Need GFI outlet help
I was using my straight iron in the upstairs master bathroom and the outlet stopped working. The two outlets by the sink have a GFI sticker on them but no test/reset button. The outlets in the other bathroom upstairs also have stopped working. again no test/reset button just a GFI sticker. There are only 5 plugs in the house with the test/reset buttons. two in the kitchen and one in the downstairs bathroom and two in the garage. I have reset all of them and I have reset all of the breakers in the panel. I can not get the plugs to work. all other plugs upstairs work but the plugs in the two bathrooms upstairs. I am pulling my hair out here please help me.
Welcome to the forums!
Unfortunately we can't help you find the protecting GFCI. It could be in your laundry room or unfinished basement or crawl space, or outside.
That sounds more like a thermal overload than a ground fault, so...
Did you turn each breaker completely off before turning it on?
OH, yeah. It is hidden by stacked boxes, or a piece of furniture. I am assuming you don't have a GFCI breaker to control these receptacles? Did all the GFCI's reset when you tripped them? Trip each one with the black button and reset each one. Otherwise it is just going to be like an Easter egg hunt for the faulty tripped receptacle.
Thermal Overload
what is a thermal overload mean
I am thinking you may have a bad connection in a back-stabbed receptacle.
You need to identify which breaker in your service panel controls the problem circuit.
If the iron has a ground fault, it probably would have tripped a GFCI device, somewhere, as soon as it was plugged in, but you stated that you had been using it for a while. GFCI receptacles are not circuit breakers, they do not trip on overload.
I was thinking of a hair "iron" rather than a clothes iron, and many of them have GFCI's built into the handle. Wifey's would trip the GFCI on both the unit and the wall for some reason. It's now a part of the local landfill
Got tire of that stuff.
I too think a connection has failed.
Please read the troubleshooting sticky at the top of this forum.
