Hot water heater timer wiring
Old 11-11-13, 05:19 PM
Not sure if I wired in my new water heater timer correctly. There was no ground wire coming from the hot water heater; just black and red. From the wall was Black, White, and a ground. I connected the ground wire to the timer box, but I don't really see what good that does. How is it grounded if the box is just sitting on top of the water heater?
Old 11-11-13, 05:28 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
BUT.....there is a green grounding screw at the splice box on top of the heater, your ground wire connects to that screw.
Old 11-12-13, 02:43 AM
So should I detach the ground wire from the screw in the timer and attach it to the screw on the water heater?
Old 11-12-13, 06:05 AM
CasualJoe's Avatar
No, the timer needs to be grounded too. From the timer you are running two hot #10 load wires to the black and red wires in the splice box on top of the water heater, right? You also run a #10 ground wire from the timer to the green ground screw.
Did you put the timer on top of the water heater? Typically, the timer should be mounted on a wall adjacent to the water heater or even on a floor joist above it if this is in a basement. Then, the 2 hot load wires and ground wire are routed to the K.O. on top of the heater in flexible metal conduit.
