Dimming CFLs
Received 0 Votes
Dimming CFLs
I have a cfl/led dimmer and two dimmable 100w bulbs (Sylvania) in a light fixture but the bulbs barely dim. I had the same dimmer connected to the previous fixture that had 4 led dimmable bulbs and it worked fine. I can't figure out why it's not working now. Any advise would be great. Thanks - Dan
Received 0 Votes
I should have said 100w equivalent. They are 23w cfl bulbs that are equal to 100w incandescent and are supposed to be dimmable. The bulbs I had in the prior fixture on this cfl/led dimmer were led and a different brand and worked well with the dimmer.
CFL's dimmable are all not created equal... Some dim better then others....
Additionally those CFL dimmable switchs work no better then a regular switch IMO.. Actually the old slide switch I have in the kitchen dims the CFL's better then any new switch I can buy..
It has a complete slide to off. My other one has a stop 2/3 rds down or so. I can only dim so much then after the stop its off... Cant find a switch that has a complete slide...
I hope you understand this...
It took me a while to find the bulb brands that actually dim and especially not make buzzing noises...
What brand of cfl did you find dim the best?
I'm pretty sure I got my bulb from HD, but I've seen EcoSmart elsewhere, including neighborhood grocery stores.
Neptun is all I use.. Their website is faulty and does not show the cfls at this time...
I order online locally....
Amazon.com: Neptun - Dimmable / Compact Fluorescent Bulbs / Light Bulbs: Tools & Home Improvement
I have had good luck with TCP, they make both CFL and LED lamps.
Also you must burn the bulbs in properly or they will fail... Some say burn on high from 1 hr to 4 hours...
I leave mine on high for some 4 plus hours to burn them in...
