LR Unilet covers?
Old 11-15-13, 06:56 AM
Z
LR Unilet covers?
Theres an old Appleton LR Unilet that feeds into a subpanel in my garage. It doesnt have a cover on it though. The mounting holes for a cover are on the sides of the opening rather than the top (rounded) edge like the modern unilets I see online.
Where can I get a replacement cover for this?
Old 11-15-13, 07:19 AM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
Is it a malleable iron Form 7 condulet? Take a look at thse covers, I am sure one will be the right type.
270 - 3/4" STL FORM 7 CONDUIT BODY COVER - Industrial Fittings - Blank, Screw, Wedge Nut; Trade Size 3/4 Inch; Steel; Crouse-Hinds[R] Brand; Screw Material Stainless Steel
........... or these
APPLETON ELECTRIC Conduit - Electrical - Grainger Industrial Supply
Old 11-15-13, 08:14 AM
Z
I saw those, but thats the problem.
My appleton 3/4" LR unilet opening is squared off. It doesnt have the rounded edges where the mounting holes are like the ones in the links. The mounting holes on mine are on the sides of the opening.
Perhaps the style I have is no longer made?
Unfortunetly I dont have a camera.
Old 11-15-13, 08:28 AM
Z
Went out to the garage. ACtually it says
LB unilet not LR.
However, with google image search I still cant find one with the mounting holes in the configuration I am looking for.
Old 11-15-13, 09:00 AM
pcboss's Avatar
Received 177 Upvotes on 155 Posts
You could make one from a 4 inch blank cover if you are handy.
Old 11-15-13, 10:40 AM
Z
I think I am going to have to use the modern cover and redrill the screwholes. Of course thats not UL listed though.......
I even looked on the ebay and couldnt find one.
Old 11-15-13, 01:57 PM
Received 3,627 Upvotes on 3,251 Posts
It may not be UL listed but it is much safer than leaving it uncovered.
Old 11-15-13, 04:08 PM
CasualJoe's Avatar
Without a picture we'll never identify it. I think I'd try to make one too.
Old 11-16-13, 07:20 AM
Z
I zip-tied a nailplate to the opening. The nailplate is the same width of the opening, just slightly longer.
That will suffice until I make one with with screw holes or find the real deal.
