Replace switch with outlet/switch
Old 11-16-13, 07:16 PM
Hello,
I have an exterior switch that provides power to my pool pump motor only. I want to replace the switch with an outlet/switch. Is this possible? If so, what type of unit do I need to look for at the store? Any thing I need to know about?
Thanks in advance!
Old 11-16-13, 07:54 PM
Hello... back.
That could be an iffy thing. You have GFI protection to consider.
If you want to replace an outdoor switch with an outdoor switch/receptacle combo you would probably be better off adding an additional weatherproof box and a GFI duplex receptacle next to the switch.
Where is the switch now and what is it located in ?
Old 11-17-13, 05:57 AM
CasualJoe's Avatar
OR.....changing the 1-gang weatherproof box to a 2-gang weatherproof box and installing both switch and a GFI receptacles in same box. The pump circuit may already be GFI protected. If that is the case, you just use a duplex receptacle.
Old 11-17-13, 02:05 PM
Hello,
I'm attaching two photos of the current setup. I'm aware that my new outlet/switch needs to be GFCI; don't know if the current setup meets that criteria or not.
Attachment 21425Attachment 21426
Old 11-17-13, 04:32 PM
I don't see a GFI presence in either of your two pictures.
Is there a GFI breaker in the panel for your pump ?
Is your pump 120v or 240v ?
Old 11-17-13, 04:40 PM
I can't take a picture of the rest of my setup because it is dark now, but I found an image similar to mine from the internet. As far as I can tell there is not GFI at all.Attachment 21432
Old 11-17-13, 05:11 PM
ray2047's Avatar
Thats not a breaker panel. It is a timer. PJ was asking about your breaker panel.
Old 11-17-13, 05:42 PM
Oh, I assumed that since the power went through the switch to the timer and that I don't see any evidence of a GFCI that there isn't one. I have no idea if there is one in the pool pump itself. It is 120.
Old 11-17-13, 07:03 PM
ray2047's Avatar
Not the pool pump the breaker boxer where the power originates.
Old 11-23-13, 03:50 PM
Okay, not to be an idiot, how would I know if there was a GFCI in my breaker panel? Attached is a picture of my breaker panel. I'm guessing that I don't have one in my breaker panel. So, I'm still left with the question of, can I change out my switch to as switch for the pool pump and an outlet?
Old 11-23-13, 04:10 PM
ray2047's Avatar
A GFCI breaker will have a test button.
Old 11-23-13, 04:19 PM
Okay, there definitely is not a GFCI in my breaker panel. So, now, can I change out the switch with a switch and GFCI outlet?
