another electrical issue
Old 11-17-13, 10:54 AM
1
I have 3 lights I am trying to connect to one switch. My problem is the switch is not powered. the power actually comes in the box where the first light is that is closet to the switch. so no power at the switch. I connected all blacks together then all whites together and breaker tripped. I am stumped. Can someone point me in the right direction please? Thanks.
Old 11-17-13, 11:03 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
The new lights need to be connected to the existing light or you need to replace the cable to the switch with a 3-conductor cable.
Old 11-17-13, 11:36 AM
chandler's Avatar
Received 6 Votes on 6 Posts
If you connected all the blacks and whites together, including the black and white from the switch, then that's the problem. That is a switch loop and technically both wires are "black". Connect the white wire from the switch to the black hot group in your ceiling box. Then connect the black wire to your black going to your lights.
Old 11-17-13, 07:06 PM
1
so what do the white wires go to? And to be clear the white from the switch to the black hot in the ceiling box? or all the black wires? and the black wire from he switch to the black wires from the lights?
Old 11-17-13, 07:12 PM
chandler's Avatar
The white wire from the switch to the hot wire(s) in the ceiling box. Black wire from switch to black wire on light. All other white(s) wire nutter together and connected to the white wire of the light via pigtail.
Old 11-17-13, 07:34 PM
ray2047's Avatar
Here is a diagram on how to connect the new light.
Old 11-17-13, 08:19 PM
1
Thumbs up
thanks guys. very much appreciated. I am sure I will be on here often, we are restoring a farmhouse built in 1881.
