Bizarre Outlet Failure
Received 0 Votes
I was working on fixing the pump on an espresso machine, needing to plug and unplug into an outlet on my kitchen counter. It is possible that water touched contacts inside the espresso machine but when I went to plug it in again, no juice.
Now, all the other kitchen counter wall outlets are working, including a GFI outlet next to the right of the problem outlet, but on the other side of the sink. I suspected a circuit breaker had tripped so down to the panel, but that was not the case. I tested the neighboring GFI and actually all the other GFIs in the kitchen and even the others I have in the house. I am not finding any other circuit or device disrupted by the same outage affecting this outlet (standard 3 prong 15A).
I put the tester to the terminals on the outlet thinking maybe the outlet had failed, but still no AC. Then I shut off all kitchen circuits at the main panel, disconnected the troublesome outlet, returned the breakers to ON and tested the supply line now unattached from the outlet. Still no test for current.
Now I am at wit's end feeling that something tripped, but I have no idea where. Again, nowhere else in the house have I found power interrupted. Any thoughts?
just the normal bulb shirt pocket tester. also pluggin in a small lamp fails.
Received 0 Votes
Yes, normal 15A wall 2 outlet 3-prong. I have a multi tester but this suffices to tell me the circuit has no juice. As I said, I touched white and black with the probes, no light.
The symptoms are just like a GFCI tripped or the breaker tripped. It was working, then stopped working suddenly and I attributed it to the appliance I was repairing where water was slightly involved.
Received 0 Votes
3ft to the left, but 90 degrees is a working outlet. Black to ground lights the tester. Now back to the inoperable outlet, black to ground, nothing. GFCI is next outlet to the right past the sink. It works fine.
