Capping Unused Outlets
Old 11-22-13, 10:35 AM
There are 2 device boxes on my wall up by the ceiling. I think they held sconces at one point that were replaced with outlets.
In box 1 there was orange hot from switch and another going to the next box. There was also two white neutrals connected to outlet.
In box 2 was a single orange hot and 2 whites.
I merely wirenutted the two oranges and again with the two whites in box 1. In box 2 I wirenutted the two whites and put a nut on the lone orange.
I put blank cover plates on both. I might redo them with sconces down the road or I may leave it permantly....
Is there anyharm abandoning this as I have done?
Theres another outlet I am considering removing as well..... only it iis not switched, it actually in the middle of the run with other outlets.
Is there anything I should consider here?
Old 11-22-13, 04:25 PM
canuk's Avatar
Sounds like you did good -- especially buy putting blank covers on.
If you want the other outlets to remain live --- after removing the outlet join the hots together and wirenut them --- same as the white neutrals --- put a blank plate on and you're good to go.
