useing Murrary QP breaker in a Siemens indoor load center
Received 0 Votes
I think that I have done this before but aren't sure. I have a Siemens indoor load center (18 years old) and the main Siemens MP-T 125 amp breaker is going bad, I can't find a MP-T breaker locally but the guy at store said a Murray QP 125 Amp model MP 2125 is a good replacement breaker. I just want to know if he is right before I order the Murray. I live in the boonies and have been told we don't have a local electrical code.
Thanks
Thanks
Received 0 Votes
The Seimens 125 breaker isn't available. It is funny that you can ask a question and get so many answers except the one that answers your original question. Thanks anyway for your time.
Murray 125-Amp 2 in. Double-Pole Circuit Breaker-MP2125 at The Home Depot
The equivalent breaker with the Siemens label would be this one and is commonly available.
125 Amp 2 in. Double-Pole Interchangeable Circuit Breaker-Q2125P at The Home Depot
Therefore, the Murray circuit breaker you asked about IS NOT EQUIVALENT to the Siemens breaker you now have.
Received 0 Votes
FYI:
This is the product overview list from the Murray Breaker, The new 125 Amp. Murray. It has the exact Specs and labels as the SIEMENS breaker, except the Murray label. Notice that it is listed in the product overview as
The Siemens 125 Amp 2 in. Double-Pole Interchangeable Circuit Breaker
PRODUCT OVERVIEW
The Siemens 125 Amp 2 in. Double-Pole Interchangeable Circuit Breaker features plug-in installation and INSTA-WIRE connections. The breaker is rated for a maximum load of 240 volts and has up to a 10,000 AIR. This breaker is intended for overload and short-circuit protection of your electrical system.
Use for overload and short-circuit protection of your electrical system
Helps protect your home's wiring from high temperatures caused by excess current on a wire
Thermal-magnetic
Common trip
Plug-in style
120/240 VAC
10,000 AIR
Interchangeable
HACR rated
ANSI certified and CSA- and UL listed
Note: Product may vary by store
MFG Model # : Q2125P
PRODUCT OVERVIEW
Thermal-magnetic
Common trip
Plug-in style
120/240 VAC
10,000 AIR
Interchangeable
HACR rated
Thermal-magnetic
Common trip
Plug-in style
120/240 VAC
10,000 AIR
Interchangeable
HACR rated
Thermal-magnetic
Common trip
Plug-in style
120/240 VAC
10,000 AIR
Interchangeable
HACR rated
I don't think either one will replace a Siemens MP-T125. I still cannot find anything on a Siemens MP-T125 breaker and am beginning to think it must be a Murray breaker instead of Siemens. Go ahead and order from the hardware store guy if you think you can make it work, but I think I'd just replace the panel.
Putting a Murray breaker in a Siemens panel is technically the wrong thing to do but works in most cases. With a main you need to be carefully though as sometimes the mounting is strange. Can you read the paper label in the panel and tell us what it says to use? A picture helps.
OK, MP for multi-pole? How about this one?
mrmackc
Received 0 Votes
There isn't a Siemens 125 breaker being sold as such, that I can find. Lowes and Home Depot stores, depending on where you look, both sell Murrarys but not a Siemans 125 amp. The 125 Amp Murrary is the same breaker as the old Siemens brand with a Murrary sticker on the side. I suspect that the reason for the dropping the Siemens 125 breaker is a marketing decision, since Murrary and Siemens are the same outfit.
BTW the new Murrary breaker performs really well in the main breaker slot, this one takes up a standard double breaker (2 single slots)
Which Siemens breaker could you not find? Was it this one?
They may not be stocked at all stores, but they can order it for you or you can order it yourself and have it in just a few days.
