unbonding sub panel
Old 11-27-13, 05:59 PM
unbonding sub panel
Hi again
I have a main panel that is now a sub panel because of adding a main disconnect outside. when I change the wires back to neutral & ground bus some wire will be to short. is it a code violation to splice wires with wire nuts before
installing on bus?(to add length) the former owner had some net & grounds on same bus because this was the main panel before adding outside disconnect....
Thanks again G
Old 11-27-13, 06:00 PM
pcboss's Avatar
You can splice additional conductor length to reach the bus.
Old 11-28-13, 03:10 PM
unbounding sub panel
Hi
Thanks for the reply! what a great information site....Thanks G
