Another drum switch
Old 11-28-13, 06:55 AM
Post Another drum switch
I have the same drum switch but my motor is a six wire not colored but labeled. on 1 line I have T1 T3 AND T8 on the other line I have T2 T4 AND T5 I am trying to figure out how to wire this to the drum switch. Any help would be appreciated.
Old 11-28-13, 07:01 AM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
Welcome to the forums!
Just to keep things neat and tidy I have moved your post to its own thread. That way we won't get confused with the other thread info and your info.
What motor do you have? Is there a wiring diagram? Some times it is on the inside of the wiring compartment of the motor.
Switch diagram:
Old 11-28-13, 07:04 AM
drum switch
it is a rockwell motor made by leeson the # i have is C6C17FB12A D77. I have pics but i do not know how to post them. Thanks
Joe
Old 11-28-13, 07:05 AM
Here's how:
http://www.doityourself.com/forum/el...-pictures.html
Is this on a drill press? Is the number off the machine or the motor itself? Do you want it to reverse the rotation of the motor?
Old 11-28-13, 07:09 AM
Old 11-28-13, 07:11 AM
Nope. Try again. You can also upload them to a hosting site like Photobucket and then link them here.
Old 11-28-13, 07:13 AM
Lathe
Tolyn, it is off a lathe. I would like to reverse the motor for sanding.
Old 11-28-13, 07:17 AM
ray2047's Avatar
Those are links to your email not pictures. Notice they don't end in an image file format such as, JPEG, JPG, PNG, GIF, BMP. http://www.doityourself.com/forum/el...-pictures.html
Old 11-28-13, 07:20 AM
Pics
Old 11-28-13, 07:24 AM
You are using the low voltage wiring correct?
What is the note on the top? I see "CCW rotation facing XXXX XXX interchange leads T3 and TX for CW"
Old 11-28-13, 07:27 AM
Toyln
Yes i am using 110v the note says interchange t5 and t8 cw rotation.
Old 11-28-13, 07:42 AM
I don't really know which is the proper "forward" rotation you will just have to try this. If it is wrong (forward is reverse, reverse is forward) Just interchange wires 5 and 8
Switch Terminals:
1) wires 1 & 3
2) line (hot or neutral)
3) wire 5
4) wire 8
5) Wires 2 and 4
6) line (hot or neutral)
Old 11-28-13, 07:51 AM
Thanks Tolyn, just to be clear i have a pic of the drum switch diagram. if I am in the wrong direction it should be easy enough.
Old 11-28-13, 08:02 AM
Yup. That looks lovely.
Old 11-28-13, 09:12 AM
Worked like a charm. Had to switch t5 and t8 like you said I might, but it is finally up and running.
I wish I had found this forum 2 days ago, but it was worth it. Enjoy some turkey today and have a happy thanksgiving.
Joe
Old 11-28-13, 09:48 AM
Very nice! Thanks for the update.
Old 03-08-14, 11:11 AM
New motor with different wiring
I just replaced the motor on this lathe, the new motor has a different wiring diagram, but my drum switch is the same. I have tried to wire this but I don't want to fry the motor. Any help would be appreciated.
Thanks
Joe
Old 03-08-14, 11:48 AM
Welcome back! You burned up the motor?
New connections:
P1 to neutral (not connected to switch)
Switch 1 = Hot and T4
Switch 2 = T2
Switch 3 = T5
Switch 4 = T8
Switch 5 = P2
Switch 6 = T3
Again, if rotation is not correct, interchange T5 and T8.
Old 03-08-14, 12:11 PM
Thanks Tolyn,
don't know if this matters but P1 and P2 go thru a reset switch on the motor:
no I didn't burn it out but the motor bearing is on it's way and starting to squeal. I figured I would keep the motor and change the bearing later. However, I want to sell this next week to get a bigger lathe.
Thanks again
Joe
Old 03-08-14, 12:31 PM
The reset is for the overload protection on the motor. That shouldn't matter.
