Will This Power Supply Work For LED
HP 1000W POWER SUPPLY SAN DIRECTOR SWITCH 2/128 & 4/256 411859-001
or
HP - 1000 WATT POWER SUPPLY FOR STORAGEWORKS 2/64 SWITCH (283804-001). REFURBISHED. IN STOCK.
please Help mE YAlllll
Can't tell without knowing what you are trying to power. Saying "LED" does not help much.
First you need to match the voltage. Your lights are probably 12 or 24 volts though other voltages are a possibility. Then the power supply should be able to supply more wattage/amperage than your lights require.
Round 2.......
You still haven't told us what kind of LED you are using from your last thread.
The power supplies you have listed here appear to be network switch power supplies. Not sure they'll work for those LED's.
Emergency
these are the lights i want to power
500x 3W Red High Power LED 500pcs LEDs 3watt High Brightness Light | eBay
I really need help
I really need help
