How to Identify Hot and Neutral with this Wiring (Pic Attached)
Received 0 Votes
So I have 3 lutron diva dimmer switches, and I am trying to replace the one hanging the lowest in this picture, putting in its place a honeywell programmable switch), which has a blue, black, and white (says neutral required on box).
I figured I would just take out the lutron diva switch and see where the hot and neutral was connected, but the lutron diva switch has both black wires, and it is connected to just black wires, so I do not know which is hot and which is neutral to install my new honeywell switch. Any ideas on what to do?
You need to separate the blue wire nut from the yellow one.
Don't disconnect anything just spread them apart.
Will update pic when the wiring can be seen clearer.
RED ALERT!!!
That is not a proper box for high voltage wiring, that is a low voltage ring. This is a major code violation and needs to be replaced ASAP!
Since it is a remodel box replacing it with a proper 3 gang remodel box shouldn't be a big deal. However I see what appears to be white thing (block?) which looks like it is limiting the depth. I'm guessing you have a 2" space from the face of the drywall to the face of the white thingy?
Received 0 Votes
Why is this against code? I noticed in my house, most of my outlets are old work-remodel plastic boxes. I didn't put them there but didn't know it was against code. I do not know about the white thing, I will have to open it up again to take a look. Regardless for right now, please help me with the wiring if possible, based on this closer picture to help identify where I need to plug the blue, white, and black on my new honeywell programmble switch. So therefore, I'm trying to figure out where the current hot is.
Received 0 Votes
The issue isn't whether it is made of plastic or not. What you have there now is not a box but a low voltage device ring. The low voltage rings have no back on them. A box is fully enclosed and rated for line voltage.
You need to replace the ring with a proper box.
I don't think it is a low voltage box, but a line voltage box with the back cut out to accommodate the thin wall space. Low voltage boxes are often orange in color.
Jag, from what I can tell the black wires under the yellow cap on the right side of the picture, commingled with the blue one is the hot bunch. You can test it with a multimeter from neutral to the wires under that cap to be sure.
Your white wire will go to the neutral bundle in the back of the box. Wherever your manufacturer says to hook the hot lead, do that under the yellow cap, once you have assured yourself it is the hot bundle, then the blue wire will go to the fixture. Which switch are you replacing?
Received 0 Votes
Im replacing the switch that is the lowest in the picture. Its the furthest switch to the right in the picture.
Okay so on my new switch the blue wire needs to connect to the load, the black needs to go to the line, and the white needs go to the neutral.
So, I understand the white needs to go to the white wire neutral bundle in the back, now where should the blue and black wire go. Thanks for your help guys!
Above this switch it appears the blue capped wires come from your switch and go back into the wall into oblivion somewhere. My bet would be that is LOAD. The wires in the yellow cap adjacent to it appear to feed all the switches, and would be the hot wire. You need to get a multimeter, check across neutral to the wires under the yellow cap. They are most likely hot. Once you have found the hot wire, connect your black wire there under that cap, once you have removed the wire to the defunct switch. The other wire from the defunct switch goes to the blue cap and should be load. Without testing with a multimeter, we are only guessing. You'll have to do that on your own.
Can you please separate the blue wire nut from the yellow one.
This wiring looks like a science experiment.
I think I am seeing part of a metal box behind the blue ring or box. I am suspecting that a single or two gang ring was converted to a 3 gang using the blue "adapter".
I believe you are correct PCboss. My is this a can of worms! I think Chandler is correct (Cut off remodel box) as I have never seen a 3 gang Low voltage remodel box in the big box store. I hope the OP has good insurance.
Received 0 Votes
Based on these newer pictures does anyone actually have an idea as to where the wires for my new switch should be connected. My new switch has a blue wire needs to connect to the load, the black needs to go to the line, and the white needs go to the neutral.
Otherwise, I guess I will unnecessarily have to pay an electrician to come in, but I can easily hook it up if I knew where the wires needed to go.
When you pick up a replacement plate get one in unbreakable nylon instead of the plastic one like you have there.
#21
