What the .... Do I have going on here
Received 0 Votes
I am adding 7 circuits for a kitchen remodel. I figure I have 100 amp service but am not sure. Here is what I have, followed by my questions;
Main panel
Inside
Attachment 29568
Further inside
Attachment 38005
Panel inside garage
Attachment 24139
On door of panel
Attachment 49662
What exactly do I have going on? 90 amp service? Shouldn't the sub have a main breaker?
I Did amperage calculations for my home and came up with around 80 amps. My current sub panel is a 12 slot and is almost full. I want to add a 100 amp 20 slot unit, but realized that between 5 new 20 amp circuits and 2 existing for the ovens, I would have 140 amps worth of breakers before including all the existing and added 15 amp circuits. Is this ok? Can you have more breakers worth of amps than actual service?
Bottom line, based on what you see, can I add a larger sub panel and additional circuits with my current service?
Main panel
Inside
Attachment 29568
Further inside
Attachment 38005
Panel inside garage
Attachment 24139
On door of panel
Attachment 49662
Received 0 Votes
Yes, the house was built in the 70's. Not sure what size wire is on the load side, not quite able to look at a wire and tell. The sub panel I showed is the only other panel I have, and it is not under the main that is shown. The only load I am adding is a second oven and a range hood. New Lighting is replacing higher wattage lights which should lower my load, correct? I did not calculate my current load, just anticipated new load of around 80 amps.
Just remember, the old A-H Murray meter combo is pretty old and won't last forever. You should be thinking about maybe replacing it in the next 5-10 years. A-H Murray was a very cost effective piece of equipment in the '70s and not known even then for high quality.
Received 0 Votes
Thanks for the response. Originally I did my load calcs using wattage and came up with around 80 amps (can't remember exactly). I will redo it to confirm. I just wanted to make sure that I can put a larger subpanel in to accept more circuits and still be up to code. Just to make sure I understand, essentially I could put a 20 space panel in and use every space (40 circuits?) and still be up to code as long as my anticipated load is less that my service?
Good to know about my current main. I will consider replacing it as well.
So I can use a regular panel and make as many circuits I want as long as my anticipated load does not exceed my service load rating?
Square D Homeline 150 Amp 30-Space 30-Circuit Energy and Automation Indoor Main Lug Load Center
An aluminum bus panel is an economical choice if money is a consideration and should provide years of reliable service. Copper is more conductive, but is also more expensive.
