ground wire connections
Received 0 Votes
I've been researching how to wire up my meter to my main panel, then to a sub panel.
One thing I am unsure of is that with the larger wires for my grounding between the panels and ground rods etc, what is the recommended way to attach these wires together at junctions? Wire nut? Some other device?
The GEC between the panel and the ground rods and water lines needs to be continuous. There should be connections on the bus bar that will accept up to a #4 without an adapter.
Welcome to the forums! You will wire your meter base to the main panel and the subpanel from the main panel, not from the meter base. You will run at least a #6 bare wire from your grounding rod to the middle of the meter base and from there into your main panel. Be sure to check with your local authority having jurisdiction for any variations they may have.
To expand on the reason you need to check is that some power companies do not allow grounding to take place in the meter socket. It must be done in the service panel.
That's true, Jim. One municipality close to here requires the grounding electrode to run from the rod, through the meter base central lug and on up to the service entrance in one piece. Go figure.
Much easier to check before finding out what you installed doesn't fly and the effort is wasted.
