Mistakenly used 14/2 wire on baseboard heaters.
Received 0 Votes
Is it possible to run 12/2 from the breaker box to the junction box, and mate the 12/2 to the 14/2...???
Using 20amp breakers.
Thanks.
Thanks.
Received 0 Votes
Ok, thanks. I will simply leave the line as is, swap out the 20 breaker for a 15, and call the line 'full'.
I have 2500 watts, 240volts, 141/2 wire, and it'll now be a 15amp breaker.
Good to go..??
Thanks.
Good to go..??
Thanks.
Received 0 Votes
I think I understand the flaw in my logic(I use the term loosely)
I had figured that since each heater was on a single standalone line, that I only had to count the wattage on that separate line, the highest being 750 watts @240.
I now see the error of my ways and I thank you all kindly.
