Wiring 6 transformers 11v primarys to 220vac
If the green wire is really a neutral not a ground and is gray or white, yes but you have 240v if this is U.S. and the result will be 120 on each primary. You must use either a 2-pole breaker or two handle tied single pole breaker if this is hard wired. If it is plug in you must run a 120/240 feed from a 2-pole breaker to an appropriate 4-wire receptacle.
Received 0 Votes
Thanks for the reply. currently i have a 3 wire 12/2 cable. two 12awg hot wires with ground. i need to upgrade to a 12/3 with ground. I was hoping this would work. This is the only way i knew to do it....
No.... currently you have a two wire cable with ground. In that application you cannot use the bare ground wire as a neutral.
When you upgrade to a three wire cable. You'll have half the transformers on red and white and the other half of the transformers on black and white. The bare wire will be a true ground for them.
its a 12/2 with ground SOOW cable into a 220v receptacle
*Technically no ground, just conductors. one of which is green insulated in equipment cords such as SOOW. Feeder cable such as NM-b does have a ground but it is not counted.
