Dedicated Circuits
Dedicated Circuits
First time posting in electrical. I've always got good info from this forum. I'm trying to help a friend, without a lot of money to throw around, rewire a basement after flood damage. I'm trying to determine what equipment needs dedicated circuits by NEC code (realizing I may have to consult local code). The lights and outlets are all on separate circuits. I basically have 2 unused wire pulls (circuits) available to be used. Originally I was planning on using one solely for the bathroom receptacle. The bathroom is very small, but I plan on having a vanity light, fan/light combo, and an outlet. The other available circuit was going to be used for the newly installed sump pump. The homeowner just recently had the furnace replaced and the tech found out that the furnace is actually connected to the upstairs bedroom and bathroom circuit. I believe this needs a dedicated circuit, but it has been this way since the house was constructed in 1965.
So basically I have 2 circuits available and three pieces of equipment I'm not clear on, sump pump, furnace and bathroom. Do any or all of these need dedicated circuits. I've tried to research this online and have seen conflicting information. The breaker panel is full. I don't really want to run new pull, but if I bought a tandem breaker, it could be done if it needs to be done.
I'm really interested in what code says and being code compliant, but would welcome preferences if it is made clear what is code and what is preference.
Thanks!
Thanks!
I think I'd use the 2 available dedicated circuits for the bathroom receptacle (1 ckt) and the furnace (1 ckt). The sump pump can go on the basement receptacle circuit and the bathroom fan/lights can go on the basement lighting circuit.
Not all panels will accept tandem breakers, will this one? If you provide the manufacturer's name and catalog number, someone on the forum can help you determine that. I don't think you'll need to add any more circuits.
While I can't speak of specifics regarding NEC regulations --- up here the HVAC is required to be on it's own circuit.
Back in the old days it wasn't unusual to find many appliances ( like furnaces or fridges ) sharing circuits because the load demands were far less than today. In terms of code that setup would be grandfathered in if no changes to that electrical circuit are being made. However, depending on your local code , any changes to that circuit would require the furnace to be up to current code --- which may require a dedicated circuit. Also, some codes may require a dedicated circuit when the HVAC is changed --- even though the original circuit wasn't altered.
Code requirements aside, this is a logical common sense approach anyway, since you really don't want something like a vacuum cleaner tripping the breaker that also supplies your heating equipment.
The sump pump ( up here ) has to be on it's own dedicated non-GFCI circuit. Simply because you don't want that circuit tripped during the peak usuage demand. Again, that's a regional thing.
The bathroom would need a dedicated 20 amp circuit for it's receptacle --- GFI protected.
Having said all that --- I believe that one circuit is accounted for --- the bathroom . The HVAC may be the other.
2 cents worth.
2 cents worth.
I'm not at the house at the moment, but the house has a Westinghouse panel, circa 1965. It currently has a couple tandem breakers in it already, which can be found at the link below. If required, I can get the exact model number of the panel later this afternoon.
BR2020 Circuit Breakers by Cutler Hammer
but the world is not perfect and the OP has only 2 circuits to work with
As said earlier I can't comment specifically on NEC requirements --- here's another subtle difference between your's and our CEC requirement.
I'm okay with making the world right when it is within my capabilities. I took a look at the panel today. I think I'm double screwed. I've included photos from the panel. It appears to be a Westinghouse B10 2020CT, and looking at the close up of the diagram on the right, it appears to not be rated for tandem breakers. Then looking at the panel, there are currently 3 tandem breakers installed on the panel. I would not be opposed to running dedicated circuits to all the equipment I mention in the first post...but it looks like I may have some limitations. What makes a panel suitable for tandems? It's not just a function of the total draw in the panel? Any suggestions on a course of action? Can the tandems remain? Thanks!
You could run the sump off the basement circuit and leave the bathroom's alone except to install a GFI outlet in lieu of the regular outlet. One extra space can be used a dedicated circuit for the refrigerator and the other for a freezer if they have one or the clothes washer if it's not on one.
A tandem breaker should be 2 connected 110's for a 220 circuit.
Maybe the term I should have used is "Duplex Breaker" as noted on the breaker panel. I am mainly focused on the basement utilities...but the laundry and refrigerator are on dedicated lines. Previously the basement was all run off wires dropped down from upstairs. The idea was to separate the upstairs from downstairs and determine what fixtures/utilities needed dedicated lines. I guess ideally (even if not required by code) the furnace, bathroom receptacle, and sump pump would be on their own circuits. Outlets and lights are currently separated, but now I'm worried about the panel capacity and the fact that there are 3 duplex breakers in place on a panel that seems not to allow them. I guess now I'm looking for solutions, again what's bare minimum for dedicated circuits according to NEC, should I consider a subpanel or total replacement now, are the dual breakers already in place a real hazard?
Here's an example of the dual breaker used again:
I'd leave the existing tandem, or duplex, breakers alone and see if the inspector mentions them. If they become an issue, we can come up with another solution for you.
Whether the panel is listed for use with tandem is determined by how the manufacturer paid to have the panel listed. Your panel is only good for 20 poles worth of breakers. If the model number was something like BR2030 it could use tandems.
To solve your issue circuits could be moved out of the panel to allow a 2 pole breaker to be installed to feed a subpanel. The subpanel would give you space for more circuits.
