What contact tester and how to use?
Received 0 Votes
I keep seeing warnings saying that using a non-contact voltage tester shouldn't be relied upon. I'm going to be replacing my bathroom fan; I want to test the wires both when they're free (are there 3 of them? - black, white, ground?) and when they're attached to the bathroom fan housing's outlet/plug receptacle. What do I buy for a contact test? And, when the wires are free and not connected to the fan's receptacle, what wires do I touch with the contact tester?
Thanks
Thanks
A $8-$15 analog multimeter is a good choice. Cheap digital meters can be fooled by induced voltage and can give erratic readings if the battery is failing. An expensive digital multimeter may be more accurate but you don't need to waste your money when a cheap analog will do the job.
For a beginner, I think I'd recommend a solenoid type tester rather than a multimeter.
IDEAL INDUSTRIES, INC. - Solenoid Voltage Testers
Also you can buy alligator clips to slip on the ends of the probes so you can connect with the power off then turn the breaker on. Much slower testing but safer.
Nice thing about the solenoid testers (AKA Wiggie) is easy to use two handed. With a multimeter you almost need a third hand to hold the meter.
