Running ethernet beside a hot air duct
Received 0 Votes
I have a run of ethernet that I am thinking about doing where the easiest method would be to run it beside (not inside) a hot air duct that runs from my furnace to an in-floor register. This duct should never get much above the environmental air temperature, so I don't think that heat will be a problem. However there is a small amount of current running through ethernet, so I was concerned about any potential electrical issues.
So the question is: can I safely run an ethernet cable beside a hot air duct?
Welcome to the forums!
That should be OK. I would avoid having it be in direct contact, not because of electrical issues but to lessen the chance for damage to the cable from sharp edged and/or vibration.
Received 0 Votes
Okay cool. I figured it would likely be okay, but better to ask and find out for sure. I will be trying to keep it away from the duct as much as possible, but it is a LONG fish, so that might not be possible. Appreciate the information.
