Wiring a Bathroom - Will This Diagram Work?
First time post! It looks like there is a lot of great info in this site so hopefully someone can help me out. I am wiring a bathroom that I am renovating. I am going to get a new breaker switch added and run the 14/2 cable right to the bathroom. There is no electrical in there now so I have a fresh start. Please see my diagram and let me know if it will work, or if you notice any way I can make it more efficient. I've done a lot of wiring in the past, but always check each new project to make sure all is well.
Sorry if it is a bit hard to read. Note the addition of 14/3 in the middle and my labels of "r" for red ("w" white and "b" black).
Note that I did not add grounds in the diagram. I know how to wire grounds.
Thanks in advance for the help!
I hope the image is clear enough. I'm thinking the plan is to run 14/2 to two GGCI's then to two lights (introducing 14/3 for the lights and switch), power going past the two lights to the switch that will control just those two lights. Power going to two additional switches, which will control a (switch 1) fan and (switch 2) two lights each.
The NEC requires this to be a 20 amp circuit and I'd think the CEC would too.
Mike, the circuitry you've drawn won't work. For one thing, you're showing the second GFCI getting its line feed from the LOAD terminals on the first GFCI.
You'll need to check with the CEC, but under the NEC you would need two circuits to do this. Both could be 20A circuits, one to each bathroom, feeding the GFCI and coming off its LINE terminals for lights and fans and off its LOAD terminals for any additional receptacles. All #12 wire.
Alternatively, one could be a 20A circuits feeding a GFCI receptacle at the first location and coming off the LOAD terminals to feed all additional receptacles, including those in the second bathroom. All 12-2 wire on this one. The second circuit could be a 15A circuit with #14 wire that would frrd all the lights and fans in both rooms.
Basically, it's just a call.
Thanks for the input so far guys, much appreciated!
20 amp switch is no problem. I don't have one in the breaker box yet so that is actually what I was planning on having installed.
It is actually one bathroom all of this wiring is for.
If it is only an issue with the GFCI wiring, can someone correct that for me so the rest of the diagram will work? GFCI have always been a bit confusing to me.
When you wrote this:
