Reload this Page >
Wall switch to control electrical outlet for a dishwasher... Required?
Old 12-06-13, 02:52 PM
T
Is a wall switch to power an outlet that the dishwasher is plugged into required? I don't really see the need for one. If you are working on the electricity, or if you need to disconnect the dishwasher, then the safer thing to do is turn off the breaker.
Do you guys put a switch in for a dishwasher? Where? On the wall? In the cabinet?
Old 12-06-13, 03:24 PM
P
Received 1,446 Votes on 1,300 Posts
No, no switch or disconnect for a dishwasher.
Old 12-06-13, 03:37 PM
A
Received 3 Votes on 3 Posts
With a receptacle, no disconnect needed.
Hardwired, we put in a switch. The local inspectors require it. We can put it on the wall or under the cabinet or sink.
Check with your AHJ.
Old 12-06-13, 05:21 PM
CasualJoe's Avatar
Received 152 Votes on 135 Posts
Generally you do need a disconnect, but the plug can be removed and qualifies as the disconnect. That being said, that are many, many thousands of dishwashers out there that were originally hardwired that do not have any type of disconnect.
Old 12-06-13, 05:52 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
If the DW is hardwired either a switch or a breaker lock is required to serve as the disconnect.
