Is this ground wire DOA ?
Old 12-07-13, 09:55 AM
I opened up a basement wall and found a small crack in the cement, the ground wire and everything in that section of the wall had humidity damage.
Can I splice in a new section of ground wire or am I best to change the entire length?
Thank you,
Old 12-07-13, 10:14 AM
It would be best to replace the entire wire. Otherwise you would have to use special crimps that require an expensive tool to crimp them.
You can use insulated wire for the ground..... it doesn't have to be bare.
Old 12-07-13, 11:31 AM
PJmax
Thank you.
I have a 100 amp entry now, but will update it to 200 amp next spring. What size would be best to install for the future upgrade?
The local store shows 3ga 7 strand green insulated wire for 4 dollars a meter, will that do the trick?
Old 12-07-13, 11:56 AM
If that is the ground wire that goes to the water supply line and you are planning an upgrade to a 200A service I would run #4 THHN or THWN.
#3 is slightly larger and is also ok to use.
Old 12-07-13, 12:26 PM
Will get this done tomorrow,
Thank you!
Old 12-07-13, 12:50 PM
Why does the wire need to be replaced?
Old 12-07-13, 02:46 PM
I may be wrong, but the copper is deteriorated and will even more so over time.
When I rebuild the wall, I don't want to have any issues in the future once it is concealed again behind the wall. Better to just be 100 percent and never have to think about it again.
Old 12-07-13, 02:49 PM
Deterioration is one problem and it will need to be changed when a service upgrade is done anyway.
Old 12-07-13, 04:41 PM
Good point about the service upgrade. I just can't see much deterioration in the picture.
