Reload this Page >
Wired 3 & 4-way switches. Works but 2 lights are at half power.
Old 12-08-13, 11:31 AM
Hi, I need help. I've researched my wiring problem and figure I must have it wired serial when it should be parallel and think the problem is at light #2 with the incoming power. I don't know what I did wrong or how to fix it. Light #1 and light #2 are very dim. Any help is greatly appreciated. Here is a diagram of what I have:
https://www.facebook.com/photo.php?f...8&l=02f828f010
Old 12-08-13, 11:51 AM
Welcome to the forums.
When you have a three way or four way system setup..... all the lights must come from the same end. You can't connect lights to the circuit at different points.
We can correct your illustration but that doesn't help you running wires.
ray2047's Avatar
Sorry but your wiring isn't even close.
Old 12-08-13, 11:52 AM
Tolyn Ironhand's Avatar
You have a few things going wrong here:
The white from light 2 to S1 should be on the common terminal.
The white between S3 and Light 3 should go to one of the travelers of S4
Make sure all the whites going between all the switches are colored black.
The big one:
You can't have lights on both ends of the 3way/4way switches unless you do some non-standard wiring, which you don't have enough wires anyway. You need to run a 2 wire cable between light 3 and light 2 (or light 1). Wires between S3/S4 and light 3 should go away.
Black from S4 to light 2 needs to be connected to the common screw of S4.
Name:  New diagram.jpg
** Note: PJ's and my diagrams are similar but are just different ways to do it.
Old 12-08-13, 11:54 AM
Thanks for the help. Guess I'll start over.
Old 12-08-13, 11:58 AM
Smile
Thanks Toyln. That's easier than totally starting over.
Old 12-08-13, 12:32 PM
ray2047's Avatar
See my revised diagram. A bit crude but only requires adding one cable. but Tolyn's is better.
