Need help finding a particular switch
Old 12-10-13, 09:49 AM
Hello,
5631-2W > Decora<sup></sup> > Switches > Electrical Wiring Devices > Products from Leviton Electrical and Electronic Products
Is there a dimmer version of the switch above (or similar item)? I'm looking for a single pole, rocker style, illuminated (when off) 20 amp dimmer switch.
The dimmer will be used with a single 60 watt incandescent bulb and four 50 watt Halogen GU10 bulbs.
Thank you in advance for any assistance you can provide.
Old 12-10-13, 12:50 PM
Nashkat1's Avatar
Welcome to the forums!
The Leviton site is being a bit slow right now, so I can't tell for sure, but it looks like their DVW600PH dimmer does what you're looking for.
Old 12-10-13, 01:27 PM
pcboss's Avatar
You only need a 600 watt rated dimmer. It does not need to be rated for 20 amps.
Old 12-10-13, 04:54 PM
CasualJoe's Avatar
You may want to rethink your choice of lamps, the 60 watt incandescent lamps are going away January 1st if I remember correctly.
Old 12-11-13, 08:32 AM
Thank you for all the responses.
So even though the line feeding the switch in on a 20amp breaker the switch doesn't need to be 20amp rated?
Old 12-11-13, 08:47 AM
pcboss's Avatar
The switch only needs to be sized for the load.
Old 12-12-13, 06:39 AM
Perfect - thank you for the quick responses!
