100- Amp Dual Panel Meter Box
Old 12-10-13, 10:32 AM
Anybody know where to get a decent priced dual meter box for a PUD that is similar to this? So far the one I found is 400.00!
The clips are bad inside this one so we have to replace the whole meter! ARGH.
Old 12-10-13, 11:17 AM
ray2047's Avatar
Two meter cans and a trough? Trough at top feeding drop to both.
Old 12-10-13, 04:42 PM
Tolyn Ironhand's Avatar
I did do a google search for "duel meter socket" and found this: Eaton 125-Amp Dual Ring Meter Socket-1MP2122R at The Home Depot
This might be better for you as the other one is underground only: Shop Milbank 400-Amp Ringless Single Phase (120/240) Meter Socket at Lowes.com You will just need to add some outdoor disconnects.
Square D by Schneider Electric 2 Gang 100 Amp HCP Meter Socket-1009693 at The Home Depot
Square D by Schneider Electric 100 Amp 2 Position Ringless Meter Socket-UHT2R1421C at The Home Depot
You will need to check to make sure your power company apporves this equipment as some require bypass handles.
Old 12-10-13, 05:20 PM
CasualJoe's Avatar
You need to tell us the desired amperage rating of the whole unit and then the amperage rating per position. Also, the conduit and wire size up the riser would also be helpful because you'll need to buy a hub too. I am assuming this is just single phase and the two switches below are just 100 amps each, but we need to know for sure. I wouldn't rcommend replacing the 2 gang meter socket without replacing the two switches at the same time.
Don't forget, the power company may be your best source of information because anything you buy will have to be approved by them anyway.
Old 12-12-13, 05:04 PM
100amp per position, called the power company, they said they don't have anything to do with it lol. No help at all.
Old 12-12-13, 05:35 PM
CasualJoe's Avatar
Tolyn gave you two good choices.
Old 12-12-13, 07:28 PM
Call them back and ask them what are their meter socket requirements for a residential service. (minimum amps and bypass requirements)
Old 12-12-13, 07:45 PM
Justin Smith's Avatar
I would take this as the perfect opportunity to upgrade to 200A.
Old 12-13-13, 05:53 AM
CasualJoe's Avatar
I have run into this before in small rural municipalities with their own not-for-profit public works, they really don't care as long as their meter fits and they can bill the customer. Most power companys, however, will have an approved list and some are quite extensive.
