Dimmer/fan controller for two fans
Old 12-10-13, 12:30 PM
R
I currently have two outside fans with lights. Each fan draws .68 amps and has three 40w bulbs. There is a single switch with power (b,w,grd) and a three wire cable from the fan (b,w,r,grd). Is it possible to have a dual controller dim the lights and control fan speeds? If so what do I need.
Old 12-10-13, 01:13 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
For each fan/light combo?
Yes.
There are lots of options. If you only want wall controls, a Hunter All-Fan/Light Dual Slide Preset Control, Model 27183 is probably a good choice.
Are the switch boxes outside also?
Old 12-10-13, 01:33 PM
R
No the switch boxes are inside
Old 12-10-13, 01:39 PM
Nashkat1's Avatar
Then the control doesn't have to be weather resistant. The one I linked to will work. Is that what you were looking for?
Old 12-10-13, 01:57 PM
R
More information
I might have mislead everyone. I have two fans controlled by one switch. The Hunter model 27183 does not say it will support multiple fans. Will research a little deeper.
Old 12-10-13, 02:00 PM
Nashkat1's Avatar
It should....................................................
