Rewiring an old building
Received 0 Votes
Good Morning,
I have a question regarding splices in a wiring chase.
I have a junction box that will be located above a drywall ceiling and would like to eliminate it without having to run many feet of #6 three wire cable, the cable is spliced in a junction box and one feed is to an air conditioning outlet and the other to a range. I would like to move the range cable to another location in the basement ( I have enough wire to go straight through) but would like to use an underground splice kit to wire the AC cable and remove the junction box. Is this a legal way of handling it? Other wise the junction box will be in a difficult spot to access.
Thanks in advance
Thanks in advance
Received 0 Votes
Rewiring old building
Yup, I figured as much, There were a lot of ugly things done by the original building owner that I have cleaned up , But I thought it would be worth asking
Thanks for the reply
