How to wire 3 switches controlling 3 different lights
Old 12-16-13, 06:57 AM
P
Received 1 Upvote on 1 Post
2 switches in a double junction box controlling outside light and vestibule light.1 switch in a single junction box controlling hallway light.The source comes inside the double junction box and connects with the hallway switch on the other side of the wall.Is there any diagrams for this application?Someone can explain how to hooked everything up since the switch controlling my hallway light is not working.There is a lot of wires in that box...blacks,reds and white.I replaced the switch thinking it could be the problem with no luck.I upgraded the light fixture thinking it could be the problem but again with no luck.I checked for loose connection and burnt wires but found none.Any suggestion will be appreciated.
Old 12-16-13, 07:27 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
It may help us if you removed the power from the circuit(s) pulled the switches and post pictures of all the wiring. Good clear pix are best.
Old 12-16-13, 10:26 AM
P
It was a wiring error...problem is fixed thanks to my electrician neighboor.
Old 12-16-13, 10:52 AM
chandler's Avatar
Glad you got it. Always good to have an ace in the hole.
