Need help testing amplifier fuse please?
Hey guys, I wish to test an amplifier fuse, it is a cylindrical shaped small fuse about 1" long with 2 nickel colored end caps, glass in the middle and a straight metal strip inside the glass from one end to the other. I have a DMM and I am seeing on the net that I need to set the selector to the Ohms section but in that section I am seeing 20m, 2m, 200k e.t.c, which setting should I be selecting here please?
When you touch your probes to the end of the fuse..... basically if the meter moves.... the fuse is good.
1.3 ohms is perfect.
