Wiring a half-hot outlet with 2-wire romex
Received 0 Votes
Is this possible? I installed a instant hot water tank under my kitchen sink. The existing dedicated 15 amp circuit for the garbage disposal is of coursed tied to a switch near the sink.
Power from the panel goes to the switch and then to the outlet via 2-wire romex. My problem is the 2-wire romex from the switch down to the outlet cannot be pulled out. I believe it is stapled to the studs on the way down. There is one turn on the way down to go through two studs, and without tearing up the wall, I'm not really sure whats going on. I'm thinking that even if I fish a new 3 wire down to the outlet, I won't have room with the existing 2 wire in the way.
Is there a safe way to keep the 2-wire and create a half-hot outlet?
If the power goes to the switch first the receptacle will always be controlled by the switch unless wiring changes are made and new cables are pulled.
Depending on the loads or the instructions you may need dedicated circuits for one or both appliances.
Received 0 Votes
Thanks for the responses.
I don't have great access via the attic or basement. I opened up the wall under the sink, and found 1 staple holding the two-wire to the stud, and where it makes a turn through a stud. After removing the staple, I am still unable to pull the old wire out.
The remaining part of the wire is behind the dishwasher. No access to pull any more staples out. I tried to fish a coat hangar down, but I can't really see me getting through the stud without a 1 in a million shot. Is a store bought wire fisher easier to navigate? The turn through the stud is just barely big enough for another wire. Should I continue with this plan, or work on a new circuit and go through the basement. This would be much more of project in terms of fishing wire from the panel to the new outlet. I basically want to keep it as simple as possible.
- You can run a new circuit. As pcboss said,Originally Posted by pcbossDepending on the loads or the instructions you may need dedicated circuits for one or both appliances.
- You can access the other end of your existing cable to replace it with a piece of xx-3 cable by removing, and later replacing, the drywall behind the dishwasher; or
- You can access the other end of your existing cable to replace it with a piece of xx-3 cable by removing your existing switch box, and later replacing it with an old-work box.
