Pool and Booster Pump Wiring Problem
I have an outdoor double gang junction box with 2 switches. One switch turns on the pool pump; the other switch can turn the booster pump on only when the pool pump switch is on. When the pool pump switch is turned off, it turns the booster pump off too to prevent it from burning out.
An electrican installed a new wiring cable to the junction box. In removing the pool pump switch to change it, he broke a switch screw off in the junction box. After he rewired the two switches, the pool pump switch would no longer also turn off the booster pump. The electrician mounted the pool pump switch with only one screw; that prevented him from getting the junction box lid to fully close so he calked around it. After the electrician left, when I turned both pumps on together, they repeatedly popped the circuit breaker after several minutes. The pool pump will run by itself without popping the circuit breaker.
I would like to install a new outdoor junction box myself, if someone can tell me how to properly wire the 2 switches. (I would like to have the pool pump switch still be able to also turn off the booster pump to prevent the booster pump from burning out.)
Welcome to the forums.
Members email addresses are not allowed to be posted on the site. Mostly for your protection from spam.
It doesn't sound like the wiring should be too hard to handle. Replacing the box will be extremely difficult if conduit was used to install the wiring into the box.
Do you know what you have in there for wiring now ?
Can you pull out the switches and take a pic or two and post them for us ?
http://www.doityourself.com/forum/el...-pictures.html
Sorry, I do not have the equipment or knowledge to upload a picture. I hoped someone could tell me how to wire the switches before I remove the box cover. The outdoor box sits on top of 2 conduit connections. Two cable wires run into the top--one is an armored cable and the new one is a covered Romex cable. The 4.5 square box is attached at the back to a metal post. I believe I have to replace the box because the switch screw the electrician broke off in the box.
It's pretty hard to help you if we don't know what the wiring entails.
Take the box cover off and put a plastic bag over the box to keep water out.
This is outside.... correct ?
Armored cable..... is it plastic coated gray ?
Covered UF cable, I hope, as Romex is not approved for any outside use.
The junction box is outside. The armored cable appears to have a spiraled aluminum wrapping. The electrician said the new cable he put in was Romex and he covered it with what looked like a plastic conduit covering which he connected to the outlet box. The electrician really appeared to be totally clueless about what he was doing.
I will take the cover off the box tomorrow afternoon, put a plastic bag over it and describe the current wiring back to you. I also have the switch her removed. I think I will use an ohmeter to see if it really needed replacement; I am a little worried that he may have put a wrong switch in to replace it.
It might be easier to replace the box. It might also be more effective, since the existing one appears to have allowed moisture to enter and corrode the screw.
It was one of the 2 mounting screws for the pool pump switch that broke. A spring loaded cap covered that switch. The spring broke off so that cap probably was leaking water onto the bottom of the switch.
I suspect that the electrician that did the work for me knew nothing about outside wiring.
I just measured the box size with a tape measure, probably not super accurately. Originally, the electrician said he was going to change the box, too, but when he came back with parts to do the job, he did not bring a junction box.
Guys, Because my junction box has 2 conduits coming in from the bottom and two wiring cables coming out the top, I cannot take the calked in box cover off and cover it with a plastic bag. I did check the original pool pump switch that was removed and there was nothing wrong with it. This original pool pump switch has 2 brass screws on one side and two screws on the that appear to be black. The booster pump switch just had 2 brass screws on one side. Is that enough information to tell me how to wire the two switches so that the pool pump switch can also turn the booster pump off?
I was able to schedule a pool electrician to come over on January 3, but I hoped to tackle the repair myself before then if possible.
How do you plan on replacing the two gang box if there are conduits in the bottom ?
You are describing a two pole switch that would be used for a 240v motor but the other switch is single pole and is hard to envision how it's connected.
Is the pool pump 240 volts ?
Is the booster pump 240 volts ?
Everything is 110 Volts.
The way I now figure it. The brass screws on one side of the switch interupt the power going to the pool pump; and the black screws on the other side of the switch interupt the power going to the booster pump switch. And, the booster pump switch interupts the power to the booster pump. Then, the pool pump switch should be able to turn off both pumps and in the on position allow the booster pump to be turned on through its switch.
However, I will probably still wait for the pool electrician, as you suggest. I just try to save everywhere I can because I am a 76 year old retiree with two kids still in college.
This is just one of those areas where the skills need to be hired and compensated. Yes, that's more expensive - but it's also safer.
Received 0 Votes
If this is a weather-proof box , there may be a tapped opening in the back/rear of the box , possibly 1/2" / 3/4" trade-size. If so , you can "nipple" a second box to the back/rear of the existing box.
If the box is aluminum , which is a "soft" metal , possibly you could drill round holes in both boxes for a "back-to-back" connection between the two.
I should have responded earlier that the reason that there are 2 switches instead of just 1 to turn on both pumps at the same time is that the pool pump is supposed to be turned on first to bleed air out of the water filter before turning on the booster pump that runs the Polaris pool vacuum.
#21
Understood. I was just pointing out that a DPST - double-pole single-throw - switch isn't needed to do that. An ordinary SPST - single-pole single-throw - switch can so that just as well, so long as it's wired so that it controls both the power to the power to the pool pump and the power to the booster pump switch.
