Wiring schematic for Kenmore Water Softener
Received 0 Votes
My plumber just finished installing my Kenmore 80 water softener. Two wiring harnesses are unplugged. One is black/red and the other is green/white with molex connectors. There are two ports. One underneath the other. How do I know which colours go in which port?
http://c.sears.com/assets/own/896150e.pdf See page 37
I'm not sure if this is your model or not... so you may have to do some searching to find it.
But I would call back the plumber. Without those harnesses plugged in, the softener likely isn't regenerating. Which means he didn't put it through it's first cycle nor test it. I would have expected as part of the installation cost would have been at least to test it.
-Mike
-Mike
