Is this acceptable?
Old 12-22-13, 03:30 PM
Is this acceptable?
Trying to connect to panel in garage. Sheetrock in garage is 5/8's. I cannot find a 4 inch j box with 5/8 set back. J box and first extension ring get me flush with Sheetrock. Second extension ring used to come out of wall and into 3/4 conduit. I am running power to basement. Running romex from panel to j box then connect to THHN in conduit into basement. 9 total wires in conduit - 8 current carrying conductors and one ground wire. 4 circuits in basement - 3 20 amp, 1 15 amp. Suggestions welcomed.
Happy Holidays everyone.
Old 12-22-13, 04:39 PM
pcboss's Avatar
You could bend an offset in the conduit to reach the second extension ring and then install the proper depth plaster ring.
Old 12-22-13, 04:52 PM
I thought the same thing as the Boss.
Old 12-22-13, 06:14 PM
Mr.Awesome's Avatar
If he is just using this as a junction box (no device installed), wouldn't a mud ring just make it more difficult to work inside of the box in the future?
Old 12-22-13, 06:21 PM
A two gang mud ring would be the best choice.
Old 12-22-13, 06:53 PM
Tolyn Ironhand's Avatar
Just as a note most of the NM connectors, like the ones you have used, are rated for two cables each.
BTW - Welcome to the forums!
Old 12-22-13, 07:24 PM
Thanks everyone. I was reading 314.22 and it is vague about the number of extensions rings that can be used. It doesn't say I can't add two rings to one box. I imagine the conductors have to extend 6 inches out of second ring as if a device were attached? To answer Mr. Awesome - it's just a j box, no devices.
Old 12-22-13, 08:40 PM
Nashkat1's Avatar
Then you don't have to install a mud ring. You can install a 1900 blank on the first extension ting if you want to.
If you'd rather install a mud ring and a finish blank cover, you can use a flat (no rise) mud ring.
