Low profile outlet box on side of cabinet
Received 0 Votes
Recently had some free-standing cabinets installed. The installers cut-in a low profile plastic outlet box on each end of the cabinets. I wish I had thought this through before agreeing to have them cut the boxes in. The problem is the low profile boxes are the blue plastic type. I do NOT want to run romex through the back of the cabinets to terminate at the low profile boxes. I want to use the armored BX type cable for extra protection. I can think of no good way to attach the BX cable to the plastic box. I read another post that said you cannot attach BX cable to a plastic box.
I looked for a metallic low profile box in the size I need but cannot find one. The size I need is about 2" x 4" for a single outlet. Right now I see two options:
1) Remove the boxes and cover up the hole and never use it for anything.
2) Go to the machine shop down the street and have them fabricate a box to the size I need. I don't care how much it costs (within reason) I just want this install to be done properly.
Has anybody else come across a situation like this where you have to terminate armored BX cable to a low profile box in a tight space?
Welcome to the forums.
You're right.... you can't connect the MC cable to plastic boxes.
Had you known ahead you were using MC cable, the cabinet builders could have installed metal gem boxes that come in many depths...... 1-1/2", 2", 2-1/2", 2-3/4", 3-1/2".
The problem with gem boxes is that they are smaller than plastic boxes and will just fall thru the hole that was cut for a plastic box.
It is also very hard to get a receptacle in a shallow gem box with MC cable.
(shown with NM clamps)
What's behind the cutouts? Cabinet interior or space inside the base of the cabinet? Where are you planning to extend the power from?
Depending on where you've got them mounted, some 90-degree MC connectors might be useful.
Received 0 Votes
What's behind the cutouts? Directly behind the cutout is a drawer slide rail. The rail covers 1/2 of the box. Since the other half of the box is free and clear of obstructions, there should be room to mount one of those 90 degree connectors. I think I may just fabricate my own box out of steel and use that 90 degree connector.
I've already checked the clearance with the drawers and there is nothing obstructing the back half of the box. That should work.
EDIT: Even better, I found a 45 degree connector.
Wouldn't Smurf tubing or non-metallic Sealtite be code compliant?
k9,
Received 0 Votes
The power will come up through the floor into the back of the cabinet.
I already have some spare BX cable 3/8" 2-12 w/ground so I'm going to use it for this project. I have a junction box in the crawl space directly below the cabinet that has power. All I have to do is go down to the crawl space, drill a hole straight up through the floor, through the bottom of the cabinet and fish the cable up to the box.
I already have some spare BX cable 3/8" 2-12 w/ground... All I have to do is go down to the crawl space, drill a hole straight up through the floor, through the bottom of the cabinet and fish the cable up to the box.
I don't think the Smurf tubing would be. I think that's only for raceways inside pours
see no reason why it wouldn't work just fine. I've seen it before in residential wood framing too. Not really much different than installing PVC conduit, just flexible is all.
You're right about the sleeving, if that's what you're asking. And Joe said he's seen it used in residential wood framing, so it may be OK inside a cabinet.
I would dun it as conduit rather than as a sleeve to avoid having to caulk inside it. The only caulking then would be around the outside of the conduit as it enters and exits the floor.
k9, you can install non-continuous sections of the conduit and use it to protect Type NM-b at critical points, or you can run continuous conduit and install separate THHN conductors in it.
I have a GFCI breaker on this circuit already. I have some spare 1/2" conduit too. Thanks for the tip on the floor penetration.
I use a piece of Panduct attached with double sided tape to the cabinet. The NM is held out of the way of pots and pans etc. I know the Panduct is not one of the listed means against physical damage but I have always had it accepted given that people are not swinging baseball bats in the cabinet it does provide adequate protection.
#21
The only thing is that BX, MC, AC and FMC aren't rated for floor penetrations
