Wanting to run 230 service to my shop from the house
Old 12-27-13, 01:16 PM
I am wanting to run 230 service from the house to my shop to run a 15 amp air compressor and a welder or plasma cutter. The max amperage on either of those would be 40 amps. Would it be possible to make a single run from the house to the shop using a larger double pole breaker and heavy gauge wire and split it off into two circuits at a panel in the shop? The run would be about 40' and enclosed in conduit. If so, what would be the breaker size and wire gauge?
If not, would I run 2 double pole breakers and wire for each, in the same conduit to the shop?
I appreciate the help. I am by no means an electrician.
Tom
Old 12-27-13, 02:40 PM
pcboss's Avatar
Received 210 Upvotes on 181 Posts
Correct, a double pole breaker could feed a small panel at the outbuilding. The small panel would split into the branch circuits. Sounds like a 50 amp panel fed with #6 wire would be fine in 1 inch PVC conduit.
You can search this board for sub panel to get a better idea of what is involved.
Old 12-27-13, 02:46 PM
P
By code you would have to and abandon any existing power to the shop. Code permits only one feed. You would install a subpanel at the shop. You might squeak by with a 60 amp feed if you didn't use the welder and cutter at the same time but better would be a 100 amp feed. For that you would need three #3 THWN (copper) and one #8 THWN. Minimum conduit size would be 1".
See PCBoss' post for 50 amp feed info.
